How to machine polish clear, plastic convertible top windows
This is a long video, so if you have a short attention span or you simply don't have and never will need to know how to machine polish clear plastics, by all means *click* away to Instagram and maybe you can find a dog jumping through a flaming hoop.
As convertible tops get older, the clear flexible vinyl windows become filled with swirls, scratches, water spots and oxidation. In really severe neglect, the plastic can even turn yellow.
I've polished out a LOT of clear plastic windows in my life, both flexible and rigid. One of the MOST IMPORTANT factors when polishing clear plastics is the ABRASIVE TECHNOLOGY. The Dr. Beasley's microsphere abrasive technology is unique to Dr. Beasley's NSP Primers.
This abrasive technology EXCELS at polishing both soft clearcoat paint and also clear plastics. Most other abrasive technology will remove the swirls and scratches, but it will leave micro-marring behind and thus the clear plastic will be foggy looking, not clear like glass.
But if you own a classic convertible with plastic that's as bad or worse than what you see on this 1965 Oldsmobile 442 - then watch-on.
All products can be found here,
Dr. Beasley's
The Mike Phillips Forum
Dr. Beasley's
