2black1s
I just used the referenced 303 for the first time on a complete job... A motorcycle detail job. Previous to this complete job I had only used the product on a set of motorcycle wheels and a small test section of a painted fender. The primary characteristic of the 303 that I noticed then was it's "sticky" or "grabby" nature when wiping off and the non-slick nature of the finished parts.
That hasn't changed. It's the nature of the product.
Nevertheless, I decided to give it a more determinative test. I used my 2002 Harley Softail Deuce as the test specimen.
I have to say that I am really impressed with the final results. The bike looks phenomenal... The paintworks, the chrome, the plastic, even the matte black control housings.
If you can get by the non-slick attribute of this product, it impresses in every other sense. When I say "non-slick", I'm comparing to a typical wax or sealant. It's not that bad, it's just not as slick as your typical wax or sealant.
The ease of use can't be beat. Just wipe it on, let it haze, and wipe it off. As the haze time increases, so does the "stickiness" during wipe off, but as you develop your process with the product, it's no big deal.
I found the best method for wiping is to initially wipe in a single direction by placing one hand on top of your wiping towel and using your other hand to pull the towel. This will remove the bulk of the hazed product without the towel rolling or twisting under your hand like could happen if you wiped in a typical one-handed manner. Once the bulk of the hazed product is removed, follow with another clean, fresh towel and finish buffing in a typical manner.
Following this usage of the 303 on my bike, I think it was a good choice. Good enough that I'm now more inclined to try it on a car in the future.
Great Product!
Here's a link to a AGO thread I started with a description and several more pics of the detailing process...
If this type of link is frowned upon here, let me know.
Great Product!
2002 HD Softail Deuce - Extreme Detail
Today I started on a multi-day detailing job on my 2002 Harley Softail Deuce. This is no longer my primary bike and it doesn't get ridden as much as i
www.autogeekonline.net
