mga
Hey, I want to attach a pressure washer hose to the SPRAY end of a wand, then at the other end, I want to attach one of those drain cleaning tools that blow water backwards. That tool has a 1/4" quick connect male. I plan on cutting the existing fittings off and replacing the ends with one 1/4" make QC and the other 1/4" female QC.
I'm using a lightweight electric pressure washer (1500 lbs) and I want to use this setup to clear out a 3" drain line. My plan was to insert the hose into the pipe as far as it would reach, turn on the PW and use the wand to control the water.
Can someone tell me what fittings I need for this? thanks!
