Pressure hose fittings question
mga
monticello KY
Hey, I want to attach a pressure washer hose to the SPRAY end of a wand, then at the other end, I want to attach one of those drain cleaning tools that blow water backwards. That tool has a 1/4" quick connect male. I plan on cutting the existing fittings off and replacing the ends with one 1/4" make QC and the other 1/4" female QC.
I'm using a lightweight electric pressure washer (1500 lbs) and I want to use this setup to clear out a 3" drain line. My plan was to insert the hose into the pipe as far as it would reach, turn on the PW and use the wand to control the water.
